Ever heard the phrase no good deed ever goes unpunished? Anyways, I own a not so long ago working Macintosh Plus 1 MB.
I had recapped it with all new electrolytics. After I recapped it. I powered it up, it chimed and seemed like it was working, then about 8 seconds in started flupping (I'm assuming it's what it is, sounds similar to an analog telephone that's been off the hook too long, only sped up). I also removed solder, cleaned with alcohol, fluxed and soldered nice new shiny connections for flyback transformer, J1, J2 and J3.
Did some voltage checks, the 12 volt line was low at 11.88 volts when I adjusted voltage for 5 volts. The 12 volt zener measured low voltage. I've since replaced CR18 - CR21, with upgraded parts (Schottky TO220). Now the voltage looks good on both 5 and 12 volt lines that stay in spec but it still is flupping.
Display shows full screen of solid black and white horizontal stripes. Relatively fine lines.
-5v regulator on logic board at -4.99v and looks good. If I unplug logic board flupping stops and just clicks and no display.
