I'm working on a fix for this, but how many users do we have here that have a Macintosh Portable with a drive that does not successfully startup? Typical symptoms include a spinup and spindown, followed by another spinup/spindown until either the battery dies or the system errors out.
I have a backlit portable and a non-backlit portable, and Ive found that the power management 'section' of the board is....not great. Fairly newly developed ICs are far better and more efficient when dealing with power management and supply of clean power, so i'm testing a design which allows the supply of clean 12VDC to the drive to allow proper startup of the drive itself.
I'm also experimenting with an implementation of a SCSI->IDE converter and using a CF card instead of the hard drive, which should lower power requirements significantly as well.
