Fortunately getting data from the LA was really easy. Plug into ethernet, go to IP address in browser, hey look there are the files. No complicated or proprietary nastiness to deal with.
This logic analyzer data is not really messed with or organized in any sort of manner. I just hooked up the pods to my EPMGR adapter board in order and fired it up. I intend to write a little program to parse out all the bits and organize them into sensible sections, like having all the VIA data lines and PMack/req next to each other to make it easier to look through.
In the attached zip file are:
* A spreadsheet detailing which logic analyzer pod and signal goes to which pin on the EPMGR connector
* The raw binary output files (with state number and raw picosecond timestamp). These files are literally a million lines long and should not be opened unless your text editor can handle 80 megabyte files.
Looks like MESS has some information about the portable's power manager: http://mess.redump.net/mess/driver_info/m50753-based_pmu
View attachment zipArchivefor68kmla.zip
