I have a Mac Plus with 4mb ram installed that is exhibiting some weird behavior. When I try to boot it up using a SCSI disk drive with either 6.0.8 or 7.1 on 100mb disks I see the smiling mac, then a quick reboot (think 1 second span), and the smiling mac is back, rinse and repeat endlessly.
Initially I thought the disks had become corrupt. Using the same Zip drive, I recreated both disks using an SE, tested that they started the SE (also with 4mb ram), everything checked out.
Back on the Plus, same symptoms. I tried two different Zip drives, two SCSI cables, verified termination switch on Zip drives, still no go.
Mac Plus WILL boot with a floppy that has a copy of 6.0.8. So I think the RAM should be good.
Cleaned RAM contacts with rubbing alcohol and a q-tip anyways. Still no change.
Thinking it was a low voltage problem, I tried the external 800k Apple disk drive I have (expecting it to fail in the same way if there was a low voltage scenario, since it is bus powered). Worked great. Also, display is bright and sharp. So that idea is mostly out the window.
Any ideas? Also, should be noted that this exact setup worked maybe 6 weeks ago. I could try burning a System 7 startup CD, and trying the SCSI AppleCD 600e with it to see if everything SCSI is bad, however I tend to have bad luck creating bootable CDs.
I'm just about out of ideas.
