I have a Plus with a strange issue.
The Plus will no boot, no chime is present, but will display black and white vertical stripes.
The problem is not coming from the Logic Board, tested in another Plus, the LB works fine.
Testing this Analog Board with another Logic board displays the same pattern, so pretty sure the Analog is the problem.
Have not tested outputs yet, swapped the ribbon connecting Analog and Logic...same result.
usual weak spots have been welded back.
