Macintosh Plus and ROM-inator
Alright, anyone have their Plus set up with a ROM-inator?  If so, how complex was the soldering job?  The site says some assembly required :)  Just want to get a gauge of how complex this will be before tossing down $30, since my soldering skills are beginner level at best.
The idea of having a bootable 6.0.8 ROM disk with a couple games, as well as the Apple CD-ROM, AppleTalk, and Iomega Zip Driver sounds incredibly convenient.
Installed and running, amazingly enough.
My soldering is probably on par with what our site pros would have done when they were 5 years old. Somehow; all the connections work enough to boot :) it took me around 2 hours to install.
Now to figure out how to cram everything I need into 846k or whatever it is... I have 4MB of ram. I wonder if there is a way to do compression with the image to fit more into it line with the ROM-inator II.
My goal is:
Basic system 6.0.8 + AppleShare/Chooser
Moire cdev screensaver
Iomega 4.2 Guest driver
Disk First Aid
And the rest of the space with games.
Lido takes up way too much space.
Axe the games. a ROM disk needs the system, utilities, tools, etc..
Games and software should go on a ZIP disk or a floppy/hard disk. Allowing the system to boot from rom and contain the Zip driver could come in handy to access the rest on disk.
Haha priorities I suppose. I only occasionally would need Lido. Games however are the primary use of the computer :) if I can rock a few already on the system then that is good. Definitely keep the zip driver on board though for accessing everything else. Maybe I can change around the games and/or slim down the system folder a bit more some how to fit Lido.
