Hi folks,
I bought a Mac Classic on eBay recently, as part of my plan to relive some of my youth. I had various 68k machines in the mid 90s, the only one I ever got new was an Amiga. I was given a Mac Classic free as it was going in the bin, and used it on and off for about 10 years before it started to make some weird noises on boot and i sold it for spares or repair on eBay. As it always goes with me, when i get rid of some tech, i want it back! so now I have one again
Luckily this one has the full 4 meg of ram, the one I had before only had the stock 1 meg, which was limiting. I've cracked the case and the caps on the analogue board look okay (probably aren't but no obvious leaking) but the logic board has badly leaked, and bulging caps in a few places. a couple of badly corroded traces and very dull solder.
Good new is, the PRAM battery hadn't leaked at all, and looked relatively new, there's a sticker on it that says 2003 so I assume replaced around then, but I'll buy a new one or just leave it out entirely if possible.
I'll stick up some photos later today, as the logic board is currently soaking in a bath of isopropyl alcohol to clean it up a little, so I can see exactly what I'm dealing with.
Can anyone recommend a source for the capacitors to replace the leaking ones, preferably UK based? and also, is it worth going tantalum or should i stick with electrolytics?
Thanks
Thanks
