I've just bought myself a "working" Classic II with keyboard & Mouse for €40. That's a pretty good deal, since price for one of these seems to be rising. All keys work on the keyboard. Caps will have to be replaced soon. I just need the right equipment.
Two things are bothering me right now:
1/ The screen is distorted and I can definitely hear a high pitched sound
When I plugged it on last night to backup its HD using my Floppy EMU (in HD mode), I heard a really high pitched noise coming from the computer. It became louder and louder as it was transferring files. I thought to myself, there's a dying flyback in there. Then it stopped emitting any sound at all. 30 seconds later a very low pitched noise started, as if the HD couldn't spin. (I have an old SONY HD40SC drive that can't spin anymore, the sound coming from the Classic II was similar)
But it completed the file transfer without exploding.
I thought the HD was on its last legs, but apparently no. Disconnected the HD, it still does that 2mins after switching it on.
So I find myself with a dying flyback transformer. It's a E58491 MTI-LTM-002, part number 157-0129.
I don't think I can replace it with one from a Plus or SE. IMO, they're not compatible.
Anyone knows which type of Flyback I should replace it with?
Found an old one on ebay FOR $127 !!
Here's what it looks like:
I read that a failing flyback can cause a distorted screen. It's either that or bad solder joints or maybe it needs yoke adjustments? I tried adjusting the vertical centring control on the back of the unit. It won't help. Toothpicks work as an hex key alternative
What do you think I should do next apart from ordering a new flyback?
2/ Microphone holder
Previous owner stuck one of those on the side of the unit. Don't really like it. I want to remove it
But I'm afraid I might damage the case. Anybody successfully removed one of these before without making a mess of the case?
