Macintosh 128K Sad Icon error Code
Hello Folks ,
I found this 128K motherboard, unfortunately on start up chime is a little bit distorted and after 1 second of normal grey display , dark screen and sad icon with message 04A000 , I have tested Rom on another motherboard and are 100% working, message appear with and without floppy drive connected, I have tried "piggy" with some ram one by one on the soldered banks but message does not change , only pigging on g11 and g12 and f11 and f12 the display shows vertical strips on startup instead of normal grey with some black points.
Any suggestion ?
thank you !
see video
04= Bad RAM, don't look any further, you'll have to replace them all anyway sooner or later. The RAM chips on the 128k and IIc are known for going bad after some time. Some failed even back in the day.
Your piggybacking didn't work probably because you only tried one chip at at time. You may have multiple bad chips. Again, it's best to replace them all and it won't happen again.
It usually does but when multiple chips are bad, the code doesn't actually indicate anything. To prove my point, macalle69's mac error code isn't on this rather handy list. When I got my faulty 128k a couple of years ago, the code it was displaying wasn't on that list either. I had it fixed by uniserver who replaced every single one of those RAM ICs.
Single Chip Identification
Data Bit
Location
Sub Code Bits
0
F5
0001
1
F6
0002
2
F7
0004
3
F8
0008
4
F9
0010
5
F10
0020
6
F11
0040
7
F12
0080
8
G5
0100
9
G6
0200
10
G7
0400
11
G8
0800
12
G9
1000
13
G10
2000
14
G11
4000
15
G12
8000
Yes I agree  the error shown on my 128 isn't indicated in that "common error list" , I have also tried pigging all ram chips at the same time  but unsuccessfully , last time I've been able to identify 4 faulty ram , this time I think  the only way is to re-ram entirely ( it is a nasty job but I'll try when i'll be very "inspired" )
thanks everybody for your support , will update as soon as I'll do the job.
Yep! a lot of Desoldering & Soldering , I have tried to save all the old rams just for curiosity and check how many failed , 8 of those were bad !
Very nice! Adding sockets was definitely a good idea. I’ll do the same if I ever have to replace the RAM one of these.
Well... aesthetically should be better resolder like original one but I preferred socket for further “accidents “ ( hope will not happen)
