Hi,
I recently picked up an original Macintosh 128.
It works great. Boots from my Mac EMU and no issues.
The problem is the 400k floppy disk drive that came with the machine.
I've cleaned and lubricated it and 'gently' cleaned the head. The mechanism seems to work fine.
The computer will not boot from the internal floppy. The disk is accepted, spun up and spit out.
If I boot the machine from the external Mac EMU and then insert a floppy into the disk drive, it accepts the disk, whirs a bit and then says it needs to be initialized. This is for any disk inserted.
If I tell the drive to go ahead and initialize, the drive spins, the head moves and after a few seconds the disk is ejected and the Mac says initialization failed.
Is this a familiar problem to anyone? Also, I have tried different internal ribbon cables with no effect.
Thanks in advance for the help!
