MacBochs
benjgvps
Anybody know where to download MacBochs so I can play dos games on my powerbook (150) and does anybody know if the program can fit on a floppy?
Thanks
Dosbox can only run on mac os x and not my powerbook 150 which runs system 7.1.
Well, as far as I know, Bochs isn't availible for 68k Macs either. I have found some versions of SoftPC out on ebay recently, however. You could try that if you're interested.
Now that I have my iMac G3 I want to know of an emulator that will run on the iMac. I would prefer Windows 95 (I have a disk) I want to know of an emulator that will run it.
P.S. I use the hotline server so if you know of a way to use one of the emulators from there PM me.
MacBochs it is, then!
Is there a good way to get Cd-Rom support in it, In the options it said that CD-ROM support is not implemented yet. Would a different boot disk fix it?
