Mac SE/30 with MicroTouch touchscreen
Impressive! I wish I had one of those. But the only auctions I've seen of a MicroTouch are the ones you won I think. I wonder how difficult it would be to replicate one with a modern film. Hummmm...
I was thinking the same. Is this an internal card or an ADB device? snuci do you have pictures of the board(s)?
It is an internal interface board that converts the capacitive glass plate touchscreen to ADB.  This is the board inside that is stuck to the power supply with stand-offs and two-sided tape.  It takes power from the motherboard connector.  The 9 pin D-sub connector is from the touchscreen and below it is the ADB output port.  You connect that ADB port to the external ADB port.
Here is the touchscreen attached with two-sided tape to the CRT.  There is a bit of a gap.
Also, here is the technical data sheet:  https://vintagecomputer.ca/files/MicroTouch/MicroTouch Mac n Touch Brochure.pdf
Probably more than you wanted to know but it's pretty interesting.
Wow, that thing is amazing, I am jealous.  I must admit I've never heard of that upgrade but if I find one I'll snag it up for sure.
