I just have a couple of questions about my mac plus (haveing opened it today to decide what needs to be done to restore it)
do the plus's have the same problem with leaking caps on the logic board that SE's have? Is it worth replacing the caps even if they aren't leaking?
also has anyone encountered a problem where the floppy drive just clicks continuously as soon as the power is applied, or has any idear how to fix it?
Also i noticed the flyback is a 157-0042-C (that flyback is from a SE Right?) CR5 also appears to have been replaced, i do know why these where replaced (it was to "stablise" the power supply is what my dad tells me) my question here is where there ever problems with the stability of the power supply's in the plus's?
Also a strange thing i noticed is that the ? dosen't actually flash when i boot it up anymore, it just sits there, the mac will boot if i give it a bootable disk though
Thanks
Max1zzz
Thanks
Max1zzz
