Hello, I have a Mac Plus with 4mb of ram that has been recapped. I am using a bluescsi pico2 with a 64gb sd card. I go to infinitemac.com and got a system 7.1 image with a bunch of games and programs. It starts up fine, and seems to run good when doing small stuff. I am able to get it on the network and run some apps.
When I try to play Carmen U.S.A. it plays for about 5-10 minutes then it hangs. On my first play it lasted a lot longer before it froze. I am wondering if I have a bad image or is it something hardware related?
I am going to do the diode mode this weekend, and I plan on removing the ram and cleaning the sockets and chips. Could it be bad ram? I have no way to test them other than to try them 1 by 1. I also plan on cleaning and reseating all of the removable ICs. Should I get a 7.1 image from some where else and load it? I have a floppy emu I can use. I like the simplicity of infinite mac. I really have not tried to do any other games or apps long term to see if it is isolated to just carmen usa.
Thank you for all the help, and I'm glad I was accepted into this amazing group!
