I've a recently fixed (battery and cap damage) IIci which has the symptom that the voltages on the RGB lines on the video connector are very low when the machine is first powered up but they increase over a period of about a minute to the correct values. If the machine is shut down then the degree to which the voltages are low when powered up again is determined by how long the machine has been switch off for. Feels like some sort of capacitor issue.
The PCB has had all the electrolytic capacitors replaced but ti don't see any between the RBV, the RAMDAC and the video connector.
All I can think of is possibly the power supply has a low voltage when first powered up but the +5V seems stable.
Anyone seen this before?
The next thing I'm going to try is replacing the capacitors in the PSU but seeing as the voltages look OK I'm not putting much hope in this fixing the problem.
