I bought a broken Mac Classic for a Mini ITX project. I plugged it in just to see what it would do. Blank screen, DOA. I could hear something knocking around inside. What could it be?
Oh, I see what it was, a really nasty PRAM battery! Its juice had dissolved the entire holder off of the board and it also did some major corrosion damage.
Yuck! What a mess!
I cleaned the board, many vias were corroded out as well as most of the traces near them. A diode and resistor were missing, corroded off. Another resistor hanging by a thread fell off and got lost in the sink during cleaning. After a thorough cleaning of the board, I plugged it back in and the Mac powers up! But... no sound, just a checkerboard pattern.
I hadn't intended to save this Mac, but it looked like it might be fun to try. What better thing to do with a free afternoon? Looks like all the corroded vias connected the chip labeled "VIA" to the CPU, and also connected CPU to the ROM chip. I've read an inability to read the ROM results in the checkerboard, so that could very well be the cause. They will need to be repaired.
I didn't attempt to replace the missing resistors on the bottom... don't know what values they are, and I think they are related to the serial port circuits. The missing diode appears to be related to the PRAM battery. Should still boot without them, I think.
Checked all the repaired vias/traces with my multimeter to make sure they're soldered well enough and no shorts. All checks out A-OK.
Turned on the Mac and it beeped! Shows a disk icon with the question mark! HDD sounds like someone is using an angle grinder to kill a screaming cat. I guess it's shot. I try Command+Option+X+O to boot into ROM.
FUUU!
Oh well, I tried! Missed a trace or bad via maybe?
So looks like this Classic has:
- Bad motherboard (has bad caps too)
- HDD shot
- Analog board has vertical hold problem until it warms up (bad cap?)
Looks like it's a good candidate for a Mini ITX project after all.
Yuck! What a mess!
FUUU!
- HDD shot
