I'm repairing a classic. I've so far washed and replaced all capacitors on the logic board, and replaced a few on the analog board. The machine almost works fine except cold starts usually have horizontal lines on screen for the first minute or so. I assume this is due to the capacitors I've yet to replace. However, now when I do a cold start, there's a small chance that I hear a very loud pop.
I thought it must be a capacitor exploding so I switched it off immediately and later took it apart to inspect the boards. I found no blown capacitors on either analog or logic board. I plugged the computer back in and turned it on again and it started working again just like before, if not a little better. There was no horizontal lines it just started up perfectly.
The next day I turned it on and it booted again perfectly. Then I moved it into another room and it made the loud explosion sound again, then proceeded to successfully boot.
What is going on here?
