Loon powerbook duo 210 power adapter
HAL2001
I Just got a powerbook duo 210 today. I started it up. Looked at the installed files, powered it down, closed the lid an left the charger connected. After a few minutes a loud ‘pop’ and smoke came from the charger.
Is the charger salvagable?
I connected the pb to a 1400cs charger. It worked great with it.
I’m glad to hear that the Duo didn’t get fried when the power supply went.
From what I’ve seen on YouTube tear downs, the power supply is glued together and would be hard to disassemble and reassemble cleanly, but I don’t have any firsthand experience. A loud ‘pop’ sounds to me like a capacitor blowing up. There are a couple of large caps inside the supply that might need to be replaced. I don’t know if any other damage might have been done when the ‘pop’ happened.
I think this video is the one I saw that showed the power supply tear down:
Edit: two other things worth mentioning
1. Last time I looked, Duo power supplies weren’t too hard to find on eBay at reasonable prices. Obviously they’re also old, and might suffer the same failure that yours did, but buying a replacement might be a better option than trying to salvage the dead one.
2. Duos have several large electrolytic capacitors on the logic board in their power supply circuitry, which handle the input 24V and ~12-14V battery charging. Over time these caps leak, and the leaked ‘goo’ is conductive, which can result in these high voltages being conducted to other components on the logic board. Most components on the board are expecting ~5V, so this failure can be catastrophic. There’s an old thread about this risk:
And another thread about restoring a 230:
You’d want to make sure that the caps on your board match the values shown in those posts, just in case there’s an error in the guides.
Many of these duo power supplies have a RIFA filter cap which is what would have blown.
I just recapped mine preventatively.
To open I used pieces of a pencil and a vise to apply slight pressure at the seams while running my heat gun (carefully and not long enough to melt the plastic) around the seams. The case opened without cracking.
Changing the caps required unsoldering the RF shield and keeping tabs on four little standoffs for reassembly but overall not too bad. In addition to the problematic RIFA there are just a few electrolytics.
I hot glued it back together. It’s working great.
