Lisa 1.8a PSU clone by Warmech
I am building the Lisa 1.8a PSU Clone as designed by Warmech and I have a question. I have sourced all items as mentioned on the site: https://github.com/warmech/lisa-hardware/tree/main/LisATX - Pico ATX PSU Replacement
My question is, and i hope somebody has also created this replacement PSU, how to connect the Pico ATX to the board? Is it soldering the bottom of the pico ATX one-on-one to the board?
If any one as also created this power supply, i would very much appreciate a number of pictures? Also of the components that are covered by the Pico ATX/
Hi, yes i build this clone too. I put in a ATX-Connector (male) in the big PCB. Then you have to desolder the two ATX Connectors out of the Pico ATX and put in the big one from the opposite side. The 4-Pin connector is useless.
I will send you some pictures tomorrow.
Regards,Michael
Regards,Michael
Great, thanks, pictures much appreciated.
Hi,
i must correct my answer. I changed the connector in the Pico-ATX because it don´t fit in the one i used on the Lisa-PCB.
Please take a look at the pictures.
@macmike
Hi,
Regards, MichaelView attachment 72248
Thanks MacMike for helping me out. I just finished building this PSU and tested the 33, 5, -5, 12 -12 rails and all looks good.
But then I checked the schematic and saw a -100V and +300V.
Are these currents that come from the videoboard in the Lisa?
Those are for video focus and contrast. The Lisa PSU does not make them --- those voltages just go into the PSU, pass through a pair of potentiometers that stick out the back of the Lisa so that the user can make an adjustment, and then they go right back out of the PSU. It's wholly unrelated to anything else the PSU does and there is no electrical connection to the "regular" PSU bits.
I'm sure the good folks at DataPower got a chuckle out of it when they first saw this as part of the spec for the 1.8A supply.
Considering this as a backup - thought I would check in and ask how they are holding up. The soldering/assembly seems very straightforward so I was curious what the component costs worked out to be - the pcb looks fairly straightforward with companies like PCWay.
Any input is appreciated.
I am about to build this as well. Just ordered PCBs from JLCPCB. I've read Warmech's github page and assembly process seems straightforward. However I've noticed a couple of discrepancies between the instructions and the finished product picture there. Please see the attached photo.
* Instruction No 7 says you need to connect S-180-12 ground to the frame ground pad next to the molex connector but Lisa PSU's frame ground is not connected to the molex connector. In fact, Warmech seems to have done something different, You can see that the green ground wire (that is connected to S-180-12 PSU) goes to the other side of the molex connector (noted as 1 in the attached photo). I presume it is attached to the frame ground somewhere, but not sure why he did not connect it directly to ground wire coming from the mains. That's what I will do.
* Instruction No 6 says to connect S-180-12's DC output to Pico's power input, which seems straight forward enough (to supply +12V to Pico). But in the photo, I noticed that one of the black wire splits into two (2 in the photo) and one end is connected to the PCB (3 in the photo). I am not sure what that's doing, as there is no place on the PCB for this wire to go to. I will probably forget about the connection between S-180-12's DC ground and PCB.
Unfortunately @macmike's photos do not show this area so I can't tell what he's done for above points.
Hi, here a some more pictures from two units i build. Hope it helps.
Regards, Michael
Regards, Michael
Thank you very much for the photos @macmike. You did exactly what I am going to do. That is, to connect frame ground pad on PCB directly to the ground on the mains, and don’t worry about splitting one of the S-180-12’s DC ground connections into two.
Hi, you can get them from connectorpeople.com
Regards, Michael
Here was his reply.
I think you might have better luck on eBay. We probably have the male ones for the PC boards and might have the Female Cable mount ones without any contacts but then you would need to buy contacts based on your wire size and make cables. We have a $10 line minimum and a $25 order minimum.
Thanks
Peter Rothwein
NTI - The Connector People ®
31 Oak Ave Ste 400
Chalfont, PA 18914
Also preparing to build this
Anyone just used an ATX PSU (i want to use only the GaN HDPlex 250w, no Pico)?
Anybody got a good part number for the 3 pin molex connector and a fitting interlock switch? I want to keep the original PSU board original and not take parts off =)
