Got an old LC II out of storage. It will turn on, the harddrive will spin and sit at white screen for ~30 minutes before the startup chime and boots from the original scsi drive. After that, if I leave the power on, I can reboot and it will chime right away and works perfectly. I thought this was an obvious cap issue.
Here is the strange part: Just replaced all 17 caps on the board here: https://recapamac.com.au/macintosh-lcii/ and it behaves exactly the same... When booting cold, it sits at white screen, chimes after 30 minutes, then boots.
There has to be some other caps on the board causing behavior this right?
