I don't see any more corroded traces, but I do see some crusty vias. Is there continuity between Pin 2 of UG5 and Pin 15 of the EGRET? What about between Pin 20 of UF8 and Pin 4 of the PSU connector?
Hi Did any of you guys try removing the power connector first and turning on the power supply? then connecting the power connector to the logic board? This worked fine with me. It seems like the PSU cannoth handle the startup current.I recently recapped a LC and TDK PSU that was entirely unresponsive. As seems to be somewhat typical for the LC, several caps had fallen off of the board and the traces were very corroded. Before I started the recap, I did the heating test on the PSU, which greeted me with some signs of life from the system. When the power supply was turned on, the LC speaker would begin clicking, and the fan would whirl for a short period, with a frequency of about 1 second, assumedly around the same frequency that LC PSUs typically click at when they're bad.
After a recap, I am still presented with these same results. I have checked the voltages of the PSU, both with and without load. Without load, the numbers seem fine, but under load (the LC itself), the voltages fluctuate up a bit, then dive towards 0 with the click. I assume this indicates that something is still bad in the PSU, but I thought I would ask those who are more knowledgeable than me. I am somewhat worried about the machine having been "powered" (even with this bad PSU) when caps were missing from the board, possibly messing up something else.
Sorry, but that’s not correct. You can go higher on the voltage rating if you want (e.g. use a 16V rated cap instead of a 10V rated one), but the capacitance value should match the original value.There is no problem going higher.
