Hi all! I picked up an LC 520 off ebay a few weeks ago. I cleaned and re-capped the motherboard and to my surprise it booted up just fine.
However, the screen will flicker and distort as it runs. A couple times it has flickered and gone to black, which made me have to reboot the machine entirely to get it back up. I believe I can hear the hard drive spin down slightly when the screen flickers, which makes me think the issue is power related.
I took a look at the analog board and all of the capacitors look visually okay - I don't see any spilled electrolyte or bulging caps, nor do I see any cold solder joints on the bottom of the board. The flyback transformer is solidly soldered in place and doesn't seem to have any cracks in it.
Does anyone have any advice as to what I should look into to fixing this? Should the analog board be re-capped as well given the machine is 27 years old? (I hope not, because there are a LOT of capacitors!)
