Laser 128
they never seem to go for as high a price as i think they should when i see them on ebay. strange that.
is it the same power connector as the //c?
get anything else with it?
well you do get the power bricks for sale on ebay in your part of the world.
otherwise a 12v dc brick and a wee bit of fixing to put the plug on will work. the pin out info is around the web. i have a link to the page on my site on the doclist page.
good luck!
you spread them.
i cant remember the details - hence the pin outs - but if pins 2-3-4 are '+' and 5-6-7 are '-' then you get your one '+' wire and spread it so you can attach to multiple pins.
