Lapis SE/30 DPD to VGA/DB15
robin-fo
68000
With my battery damaged SE/30, I received this Lapis DPD PDS card.
After seeing a few comments from @Bolle (https://68kmla.org/bb/index.php?thr...al-page-video-card-for-macintosh-se-30.45538/), it appears to be possible to get VGA compatible signals out of this card.
The interesting this is that, although my SE/30 came with a 9-Pin ECL connector, the „Video Out“ pins on the board are fitted as well!
Is there a possibility that my card is already prepared for „VGA“ (or standard Mac video out) and I just need a matching cable?
It works! I admit the voltage divider PCB is very crude, but I can now attach a standard Mac monitor or standard VGA monitor to the video card!
My first self-designed PCB 😎
I‘ll need to source the connectors now..
Sorry for dusting this thread off, but is that offer for that PCB still on the table? I inherited a SE/30 that had this card, and I'd like to see if I can make use of it with a modern display.
I made a new PCB which I‘ll have to test first. Is now only has VGA output and needs the original bracket for the DE-9 connector.
