Language card question
bibilit
68030
Does the language card should be configured in order to work properly ?
I ask because i had two Apple II europlus at home, one did not worked (showing only square blocks on the screen) while the other worked fine, using the working one to troubleshoot the other, i removed the language card from the working one and swapped it and get it working, but the other one also worked without the card and single ram instead...
