Killed my Beige( Lobo trouble shooting steps? ).
The Power Supply ticks on when jumped, but no power when connected to the Logic Board.
I removed everything from the logic board and power supply but the 20 pin PS to LoBo, ROM SIMM, VRM, and CPU.
Logic board is not tripping the PS on.
VRM looks good, but I don't know exactly how to test it with a multi meter?
Jumper by the PCI slots for Mac or ATX is present and in the correct position.
CPU/Bus/PCI Bus jumper all look good.
Will the Beige power on the PSU if the CPU went out, or without the CPU installed?
I was reading the properties of a PCI card in OF, and I shut the machine down. Installed a different PCI card in that slot, then tried to power it back on, and just nothing.
I removed all PCI cards and the Personality card.
No Ram in the system at this time.
Any ideas?
Got it working again, set the PSU jumper to ATX, then back to Mac and now it's woking fine.
Maybe I bumped it when I was swapping PCI cards....
Is there a +5V trickle to the PCI slots?
I hope not!
I never unplug my Mac's switching PCI cards unless I'm swapping the AGP card in ADC Macs because that little dohicky by the ADC connector is always hot and you will hit it with the faceplate of the AGP card.
Pretty sure it's 28v and I know for a fact it will throw a hell of a spark show.
I hope not!
You can get a spark even from 5V, as I discovered the other day whilst twiddling with the ROM SIMM of my powered-on SE/30. Gave me quite the fright, but no damage seems to have been done.
... certainly not with the power cord unplugged ?
Seriously though, I have no idea ... and, from what I've seen of your posts, I'm guessing that you have a far better idea about the actual answer to that question than I.
Here's what I do know though:
Every Apple manual for a Power Mac that I have says to unplug the power cord before installing PCI or Nubus cards.
I didn't design or build them ... and I'm not an engineer ... but if my car's manual calls for Dexron ATF for the transmission I'm probably not going to put in Type F.
I'm just kinda funny that way ... ;)
I've never killed a Mac swapping PCI cards, and I'm willing to wager I've done it more time than the top three behind me combined.
Like I said, AGP is another matter when it has ADC.
Keeping the 3 prong power cord installed keeps the Mac grounded, so you touch the grounded metal on the Mac and you discharge the static.
There is more chance of you not using a grounded wrist strap killing the PCI card or the logic board because you are not grounded!
