Yes, the PowerWave is nearly identical to a 7500/7600/7300. The big difference is that PCC left off the video chip which provides the monitor connection and the video-in (or was it out) capability.
The PowerSurge family (x500, x600 + related clones) has the following architecture:
CPU/Memory bus:
- The CPU card is on this bus.
- The Hammerhead chip provides memory control functions and also arbitrates who gets to talk on the bus at which time.
- One or more Bandit chips. These provide a bridge from the CPU bus to a PCI bus.
- zero or one CHAOS or CONTROL (can't remember which) provides the video functions. The 8500/8600 adds the other chip (so 8500/8600 has both CHAOS and CONTROL) to add the additional video functions.
PCI Bus: The PCI bus receives data from the rest of the computer through the Bandit chip. There's a separate little chip that handles arbitration for the PCI bus. Every PowerSurge machine has at least one PCI bus. On the first PCI bus there is always the
Grand Central chip.
GRAND Central: Unless the Linux folks or other hackers have figured it out, this chips is undocumented outside of Apple. Grand Central sits on the PCI bus and provides a bridge to all of the motherboard's built-in I/O, such as SCSI, serial, enet, floppy, etc. Grand Central also contains an interrupt handler. The interrupts each have a physical signal line, one per PCI slot, Bandit and CPU and those signals go to Grand Central. It appears there are only ten, but there might be other undocumented ones.
So, for example, the 9500/9600 has two Bandits on it's CPU bus and no CONTROL chip. So it has two PCI busses (six slots total) and no built-in video capability.
The 7500/7600/7300 and 8500/8600 each have one Bandit and one CONTROL (still not sure that's the right name) providing one PCI bus with 3 slots, and some built-in video capability.
The PowerWave is simpler. It just has one Bandit and no video chip. You could look at it as either a truncated 7500 or a reduced 9500, depending on whether you want to focus on the lack of built-in video or the lack of a second PCI bus.
The 7200 is based on the Catalyst architecture, which uses some of the same components as PowerSurge but is a little different. Catalyst doesn't use Hammerhead as the center of the CPU bus. And it doesn't have the separate video hardware on the CPU bus. The CPU bus arbiter, memory controller and video output functions are all combined in the main chip, whose name I've forgotten at the moment. But the PCI bus is provided by a Bandit chip on the CPU bus. And there's a Grand Central behind the Bandit and the same I/O components.
The only different in I/O for Catalyst and PowerSurge is that Catalyst lacks the 10MB/s Fast SCSI bus that PowerSurge has. However, the fact that Grand Central is present implies that the Fast SCSI bus could be added back in. There was a rumor that PCC was considering adding a Fast SCSI bus to its Catalyst clones, but they never did.
Most of PCC's clones were based on Catalyst, except for the PowerTower Pro, PowerWave and the PowerBase.
Given that PowerSurge was Apple's high end, and Catalyst (7200) was the low end of Apple's high end, I'd say it is true that PCC was cannabilizing Apple's high end sales. But they were doing it for economy (at the time) prices. The PowerWave was a little less capable than any of Apple's professional machines, but also much more affordable.
For the consumer/education end, Apple had machines like the 6400/6500 and the 5400/5500.
Comparing PowerWave to a Catalyst clone is kind of interesting. The Catalyst clone comes with built-in video, so one more PCI slot is available. Catalyst has four memory slots instead of eight and does not interleave memory, so memory support is a little better in the PowerWave, and back in those days when higher capacity DIMMs might command a premium, having eight slots in which you could install more, smaller DIMMs might have been a big advantage. And the Catalyst clones lack the Fast SCSI bus that PowerWave has.
In theory, Catalyst can use 256MB DIMMs, so the theoretical maximum memory capacity is actually the same, but no one (AFAIK) ever built a 256MB FPM DIMM for the Catalyst machines, so in practice it's one half.
