iSub power supply pinout?
Bunsen
Admin-Witchfinder-General
68040
Does anyone know the pinout for the Harman Kardon iSub power supply? I've googled without success and tried the usual pinout archives. Got one here with a dead PS and I'm hoping to get it working again.
Any info about getting it to work with newer Macs and/or PCs would be handy too - I'm still Googling that.
Ta folks.
Hi
The iSub is USB and will work with a G5 even, just plug it in. if you still need the pinout let us know.
The iSub/ soundsticks set that I have certainly includes a separate power supply, but I'm afraid that I don't have the pinout details.
The sound is wonderful. There is a huge difference, for example, between what it pumps out and the sound native to my iMac G5. The iSub/Soundstick combo was also very noticeably better than the speaker system that came with the G4 Cube that preceded my iMac, and that was miles better than the iMac's also.
I do seem to recall having read somewhere that an iSub will not work with machines running anything after X.4. Mind you, I haven't tested this personally, as I have nothing here in the house running X.5, but I would be delighted to learn that I had read wrongly, as I'd like to keep the things going for a good while yet.
What I can tell you is that my system sounds great, and that for casual listening it would be well worth your taking the trouble to get it working.
Or a multimeter?
Don't have one, no. I have been pondering the possibility, however, so the time may well be nigh....
Today, however, I have to buy a car. I think that Herself will deem further expenditure to be verboten for a little while.
A $10 multimeter is a legitimate car maintenance expense }:) How else are you supposed to diagnose battery and alternator problems? Check that you're getting 12V to your tail-light? Etc
The iSub/ soundsticks / The sound is wonderful. There is a huge difference, for example, between what it pumps out and the sound native to my iMac G5.
iMac G5 speakers are miles better then the cold lifeless intel AL iMac speakers. Just a note :)
