Is a Performa 6400/180 motherboard compatible in a 5500/250?
YES! *does a backflip*
Thanks so much! Are you sure it'll be compatible with the extra PCI slot and all?
Well no...You'd have to swap the PCI risers. The 5500 case can only accommodate 1 PCI slot.
BTW, can I use my old 5500 plastic cover, or do I need to track down a 6xxx series plastic cover?
