The HP No. 26 will work in the original DeskJet and DeskJet Plus. I had a DeskJet Plus that I used on my IBM PS/1 for years, finally retiring it after the rollers wore out and replacing it with a newer, color-capable DeskJet 722C. The cartridge also works in several DeskWriter printers, including the original and some of the earlier 500 series plus the DeskWriter C. It's really easy to find online and HP still makes them. Of course, you could always refill your old cartridges, although I have never been a believer in doing this.
The old LaserWriter and LaserWriter Plus use the HP 92285A cartridge, which is discontinued by HP but still made by some manufacturers and can be found remanufactured online. It's not cheap, but can be had for as low as $60 if you're willing to go remanufactured. The page yield is high, though, so you won't have to replace it anytime soon and will be getting a better bargain in the end. Keep in mind that the original LaserWriters don't always fill large black areas due to limitations of the Canon CX engine, so keep this in mind if you're going to be printing images.
As for ImageWriters not selling well on the used market, keep in mind the sheer number of these machines as well as their shipping weight and alternatives. Most people who buy ImageWriters do so for four reasons--nostalgia, compatibility with a wide array of Apple systems (including the Apple III and Lisa), the ability to print in color, or the ability to print multipart forms and banners. The optional networking card is also a nice feature of the ImageWriter, but keep in mind most LaserWriters (save for a few of the "Personal" models) have this built-in. Many prefer LaserWriters or StyleWriters because of the quality of the print. If you're going to be using a vintage Mac for work that is supposed to look professional and modern, only one of these printers will do not only because the quality of an ImageWriter printout is too low to be considered acceptable in today's workplace, but also because of the lost time accumulated when using an ImageWriter. Background printing isn't supported and the printers are painfully slow on "best" mode (and not much better on "faster").
Bannermaking is the only obvious reason why an ImageWriter would be suitable for modern work. In fact, if your friends know you have an older Mac, BannerMania, and an ImageWriter, you will probably get requests to make banners for events and advertising purposes. In the past several years, I've been asked to create banners for college fundraisers, campus activities, graduation parties, and high school band booster events. The ribbons (both monochrome and color) are pretty easy to track down and the tractor-feed paper isn't too hard to come by either.
Another drawback to ImageWriters is shipping them. They aren't huge in terms volume, but are quite heavy. Shipping costs scare many away, even though there are plenty of ImageWriters still in the original box.
That being said, there are some collector pieces out there. If you want a full set of ImageWriter IIs, there are three models to hunt down. The first, produced from 1985-early 1987, is the same "white" color as the Apple IIc. The second, produced until sometime around early 1989, is platinum and has one latch along the base of the cover and a DIN8 connector coming out of the back of the printer. The third edition is also platinum but has two latches along the base of the cover and a DIN8 connector that comes out of the printer's left side, not the back. This one was made from ~1989 until the printer's discontinuation in 1996. Each generation came with its own printing of the manual, adding new machines (Mac Plus and later, Apple IIc+, Apple IIGS) in each revision with later printings excluding the sections about the Apple III and Lisa.
Imagewriter Is are harder to find, mostly because they had a shorter production run. The regular Imagewriter (1984-1985) is beige and uses standard size paper. There was also a now-rare wide carriage version of the Imagewriter I that I believe was made from 1984-1986.
To round things out, there was also an ImageWriter LQ (for "letter quality; it had a higher DPI) made in the late 1980s that suffered from quality problems. It's rare and so are its ribbons. True Apple buffs will also recall the Apple Dot Matrix Printer, the forerunner of the Imagewriter I sold from 1982-1984 that used a parallel port connector and worked on the Apple II, III, and Lisa. There was also an Apple Color Plotter that looked like an Imagewriter I at one point; it had very limited support from software developers.
The ImageWriter line is quite exciting but definitely underappreciated and often overpriced on eBay and the like once shipping is factored in. Your best bet is to look for them at school surplus and church sales, where they still show up with great frequency due to their ability to be used with more recent Macintosh models.
