Got one of these, battered pretty badly, for tinkering for $20 at the weekend, as I had a partial machine here on a rack, plus an extra logic board, and I decided it was time I had a shot at putting together a working unit. The two made one good machine cosmetically, but I had video artifacts on two of the three logic boards. The third logic board had a different heat sink and did not fit the case as shipped, so after much trial and error, I swapped the heat sink (not much in it) to try the third board, and finally got a good, working unit.
The upshot is that I have the logic board from the 17" model in a 15” case, meaning I have the Nvidia4mx in the thing rather the the 15"'s stock 2mx. Cool.
But I wanted 9.2.2 on the machine. WHAT A PITA! Could I find a working installation disk or image. Nothing worked. In the end, I had to manually copy a system folder from a Quicksilver that I found "out there" to get it to boot natively in 9.2.2. Classic worked fine, but why run a slow iMac in OSX when you can run a fast machine in 9.2.2?
Now to find a spare spot for the wee beauty!
