IIsi Chime? VGA?
I rescued a IIsi. It was missing the PRAM battery. Put in a new one, set it up and powered on. Nothing. Un plugged it, plugged it bac in. Powered on, the computer booted. :) It's running 7.0.1 and has 5 MB RAM.
When I reboot or cold start it boots just fine BUT I get no chime. I didn't see a speaker inside the case. Did the IIsi came with a speaker?
Should I hear the power on chime?
Also, I have a Viewsonic VMACK-1 VGA adapter. I set it for 640x480 and sysnc= Seperate + composite. No output.
The manual is here:
http://dl.owneriq.net/6/6e453dfc-0d33-4f01-9fcc-c85300ecebf7.pdf
Any sugesstions as to what I shuld set it to to get video out toa VGA monitor?
Thanks!
Thanks!
Here's what works on mine:
640 x 480 x (up to 8 bit color) @ 67 Hz = Mac 13"-14" Fixed Resolution
832 x 625 x (up to 8 bit color) @ 75 Hz = Mac 16" Fixed Resolution
That's assuming you have a MultiScan CRT or LCD that works at those scan rates.
There should be a speaker in there, make sure it's hooked up and re-seat your RAM SIMMs if you hear bad noises thereafter! :approve:
The IIsi, due to it's design where the speaker is directly below something THAT VIBRATES A LOT (*cough* hard drive), will commonly have a faulty speaker. Check the solder points at the speaker's voice coil wires, and check the condition of the contacts at the motherboard end (in the IIsi said contacts simply touch the MB).
I have a Griffin Sync Adapter, which is supposed to separate the IIsi's Sync-on-Green video hardware, but all of my non-SoG monitors refuse to sync and display. Only my SoG display (an LG FlaTron W2043T) reliably syncs to the IIsi. I'd get a monitor that natively supports SoG-it seems that many Flatron's do, so I'd start there. You can probably get one on eBay for $25. Or just get an Apple HiRes RGB display.
Thanks! Will check the speaker contacts.
I have the Apple Hi-Res but wanted a larger LCD disply. I guess I'll have to get a NuBus video card for it. Or the Apple Portait monitor :b&w:
Check out this thread if you haven't as yet: IIsiColorPivotII_PDS_Card_HackProject™
Also, check out LC575"s thread: Who has an Asante MacCon?
By using a NuBus VidCard you'll be giving up Ethernet. 75Hz is a fairly common scan rate for LCDs, I haven't tested that yet, but you can't beat the price of the Radius Color Pivot II IIsi Cards from macmetex. Nab one before this auction ends . . . he'll very likely be raising the price on the next batch! [;)] ]'>
I snagged a SuperMac Spectrum/8si v 1.0 PDS Card from one of his "buy it nows" and that'd work well plugged into a PDS NIC, once we get the MacCon jumper settings nailed down.
The MacCon plugs into the SuperMac Spectrum/8si v 1.0 PDS Card just fine, but not the other way around due to physical interference.
I'm really likin' IIsi hackin' a lot! [:D] ]'>
