Bought a IIci setup (including AppleColor High Resolution RGB Monitor, Extended Keyboard II, mouse, and all cables) off Craigslist for $50. Woo-hoo. :ii:
I wonder what will be inside! (Foreshadowing), maybe a DayStar ’040!
Posting said it wouldn’t boot but figured it could be another recap project. Got it home powered it up, no sound (thats just the expected bad caps) screen came on but no mouse shows up, no blinking floppy icon. The screen looks odd though, the image has square corners. I need to figure out what’s that means...
Okay, open it up, take it apart (should have done this first..), drive cage is a bit stuck, and then underneath, my first encounter with the dreaded exploded Maxell PRAM battery! >
By the looks of it this happened a while back, on the surface I though this might look worse, everything just looks dirty... any thoughts on how to begin? First clean with isopropyl alcohol? Baking soda or something to neutralize the dried battery acid? Anyone have experience to tell me how bad this is?
