The 8•24 NuBus card came today, so I decided my Friday night project would be trying to bring it up on the IIci. It was replacing what I thought was a dead SuperMac Spectrum/8 III.
Tried two monitors and no video. Moved it to a different slot, no video. Saw a thread from a number of years ago about UH1 perhaps needing cleaning (hopefully not replacement), so I set out to go ahead and check the whole board.
To my shock, this seems to be the one system I didn't strip the battery from. Thankfully it did not bomb yet. It was fully intact, and it is now pulled out. (Victory!) UH1 did seem to have some dirt and grime around it, so I cleaned it with IPA and let it dry for about an hour. Visual inspection obviously isn't everything but the board seemed fine and there was no obvious sign of leakage anywhere. (Victory!)
Powered it back on after cleaning, and still had nothing on either NuBus card, using either monitor. (Woe.) I made a floppy with TattleTech on it so I could see if the system could see anything in NuBus. The floppy drive made some odd noises and then the system said "This MS-DOS disk cannot be read. Initialise or Eject?" (It's HFS formatted, on my 1400c.) I tried Eject. Nothing happened and it popped up again. I chose Eject again and the eject mechanism came to life as normal… and then freewheeled. I had to disassemble the entire computer to remove the floppy from the drive; the paper clip hole didn't work at all.
I reassembled everything and now the eject motor seems permanently stuck on, even though there's no disk inside. I tried putting a disk inside and it became stuck too
I'm thinking the whole drive needs to be cleaned and relubricated so I've taken it out for another day. (Woe.)
One other thing I've noticed is that there's no sound. I plugged some JVC earbuds into the headphone jack in the back and hear nothing there as well – tried making beeps in the Sound control panel etc to no avail. I don't recall if it has ever chimed since I've owned it (I got it as part of a lot of old Power Macs in June). Could the lack of sound be a clue as to why the NuBus slots appear to not work? I won't know for sure if NuBus is working or not until I'm able to fix the floppy and run TattleTech, but it seems like maybe there is either more than one issue, or one larger issue.
