IIci power supply recap and component identification
chue
I am recapping two different IIci power supplies, and am having trouble identifying some components.
The first looks like a film capacitor. It is the rectangular shaped black component in the first photo with marking 2.0 uF 5%.
In the second photo, there are many yellow rectangular components. As an example, the marking on the highest yellow component in the photo reads 470nK63.
Anyone know what type of components these are? Digikey or Mouser links would be very helpful. Maybe a more important question is whether these normally get replaced as part of recapping?
The first photo is an X2 metallized polypropylene capacitor - also known as a mains suppression capacitor. The paper ones dry up and eventually burn up with a horrible smell, if this plastic one has cracks I'd replace it but is not an essential replacement.
The second photo and yellow parts are also film polyester capacitors and usually not replaced unless you have concerns. That one electrolytic capacitor I'd replace if you have gone this far.
Usually the caps you want to replace on Apple PSUs are those involved in the DC filtering stage, and not the bigger 300 - 400V ones which can be expensive and hard to source without substitute.
Thank you @Byrd for the great information!
There doesn't appear to be any visual defects on the capacitors that I asked about, so I will take your advice and leave them alone.
I do plan on replacing as many of the electrolytics and RIFAs as possible. Hopefully that brings these power supplies back to life.
From what I can tell these power supplies vary quite a bit in terms of components, even between power supplies that have the same model number. However, I think a capacitor list may still be useful to others.
The following is for ASTEC AA15830
Cap #​
Description​
lead spacing​
length​
width​
diameter​
height​
qty​
C1​
0.22uf 250v film X2​
20​
23​
11​
16​
1​
C2​
0.1uf 250v film X2​
20​
1​
CA​
0.047uf 250v film X2​
15​
17​
5​
8​
1​
C4, C5​
4700pf 250v film Y​
10​
13​
5​
10​
2​
C8, C9​
470uf 200v​
10​
24​
32​
2​
C16​
2uf 250v film​
28​
33​
15​
28​
1​
C17​
2200uf 25v​
7​
15​
34​
1​
C20​
47uf 100v​
10​
16​
1​
C21, C22​
1000uf 16v​
10​
25.5​
2​
C23​
47uf 16v​
3​
6.5​
11.5​
1​
C25, C26​
2200uf 10v​
13​
25.5​
2​
C30​
2200uf 16v​
12.5​
30​
1​
C31​
470uf 16v​
8.5​
18.5​
1​
C35​
10uf 25v​
1​
C36​
10uf 50v​
1​
C315​
2.2uf 50v​
1​
The following is for ASTEC AA15831
Cap #​
Description​
lead spacing​
length​
width​
diameter​
height​
qty​
C2​
10​
25​
9​
17​
C4, C5​
4700pf 250v film Y​
10​
13​
5​
10​
2​
C6, C35​
3300pf 250v film Y​
10​
13​
4.5​
2​
C7, C8​
470uf 200v​
10​
22​
40​
2​
C10​
47uf 400v​
10​
21​
1​
C11​
47uf 25v​
6​
1​
C20​
2200uf 10v​
6​
13​
31​
1​
C22, C23​
1500uf 10v​
6​
31​
31​
2​
C25​
180 uf 16v​
7​
1​
C27​
470uf 16v​
5​
8​
1​
C28​
1000uf 16v​
6​
31​
31​
1​
C30, 217​
4.7uf 50v​
2​
C31​
100uf 35v​
5​
8​
12​
1​
C214​
2.2uf 50v​
5​
1​
I recently bought a Quadra 650 that was sold "as-is, no power". The machine appeared to be in great condition, but upon taking the ASTEC AA15830 installed in it apart, I saw that most of the film caps were cracked and/or crumbling and one of them looked burnt. I decided to take a stab at completely recapping it. It worked and the machine now boots! Thanks for this cap list, it helped me avoid having to remove caps and lose track of them to find out some of the values that I couldn't read on my example. Just a heads up that you missed one cap; a 3300pF film cap "C6", wrapped in heat shrink next to C8 and C9.
I made a DigiKey list if anyone else is interested in recapping one of these. I used 10,000 hour Rubycon caps for all of the electrolytic caps and polypropylene film caps where possible. You could probably save some money going with less high-end caps. I had to stick with two replacement RIFA metalized paper film caps for C1 and C2 as I could not find polypropylene caps with a lead spacing that would work. I also added some 21700 battery insulators with 18650 insulators stacked on top of C8 and C9 since the stock caps had insulators on top. I also added new heat shrink to C2, C6, and C8 since the stock config was set up this way. I assume this is some protection against arcing and wanted to keep it.
Happy I could help, and it's good yours worked! Unfortunately for me, only one my two power supplies worked after the recaps. The working one was the AA15831 model, which is obviously not the same one you have. I have the non-working one stored away... maybe someday I will learn enough about these power supplies to fix it.
I'm about to recap an Astec AA15830 power supply and had someone on VAME tell me "you cannot use generic caps and some of them must be very low ESR". Is this correct? and if so, which caps need to have which ESR ratings? (Thanks for the Cap list above).
Ok thanks. Do you know which specific cap numbers those are and what ESR ratings are needed? VAME ="Vintage Apple Macintosh Enthusiasts" on Facebook.
No, I just pick capacitors which are listed under the category 'Low ESR' or 'Low Impendance' – as opposed to 'General Purpose' – in Mouser or Digikey.
