I'm working on a dead IIci floppy drive. I already disassembled the floppy loading mechanism and lubricated it, and now it moves smoothly (it was totally jammed before). Now I seem to have two problems, and they may be related. The first is that the auto inject motor seems to be stuck. I can't spin it with my fingers, and it prevents disks from fully lowering onto the spinner - it gets almost there before stopping. If I remove the motor, I'm able to fully lower. The second is that the read head motor doesn't seem to be spinning. I haven't tried manually spinning it for fear of alignment issues, but if I insert a disk, I see the disk spin, but the head does not move. Should I just try to lubricate it or is this likely to be some other issue?
