IceBook Shielding
Yes. It shields the innards from RF both internal and external. I would posit that a shield-less icebook would get crappy wifi, have audio problems from the audio cable inducting nearby signals and possibly even RAM problems. The shielding also acts as a low flow heat sink because it is made out of aluminum and pulls some of the heat away from the system board in a passive manner. It's primary purpose is to shield, but it is my educated guess that it also acts as a heatsink.
Why do you ask?
Getting the shielding back on just now almost killed me, and some people have taken the shielding out of their clamshells to make them more translucent, so I wondered if you needed shielding in icebooks.
I've taken mine out because its a pain in the butt to keep taking it in and out every time you work on it. It works just the same, same with a clamshell i had a couple years ago.
The shielding on Macs is more to meet regulations than anything else, as far as I know. Should work fine without it.
Same with the new iMac G3's. I've taken it out and there's no change is performance.
