iCab - Javascript Issues
Paralel
68020
iCab seems to work great on 7.1.1, but as soon as I enable Javascript and try to load a page that has JS on it, it freaks out and crashes with a "Type 3" error. Or complete locks up System 7 and I need to force a reboot.
Anyone familiar with this error, or what I need to do so I can run javascript with iCab in 7.1.1
iCab has a lot of bugs in the Classic versions. I consider it unusable with JavaScript enabled. I think they gave up on trying to fix it, which is possibly why the newest versions are OS X only. If you were using a later OS Classilla would be an option, but for 68K your options are very few in number.
