Hi guys,
So the saga continues...
Put together the iBook G4 with the SSD in place. Boots up great and the machine is acceptably fast now (also installed more memory)
However, when I duplicated the previous drive onto the SSD (I used DD on Ubuntu), it turns out it didn't do that magic that allows Mac OS 10.5.8 to resize the partition on the now larger drive.
The error I get is -- "MediaKit reports partition (map) too small"
I've tried two things so far:
- using Gparted live CD (doesn't work on PowerPC macs)
- deleting Bootcache and other files -- deleting the files as recommended in the link didn't go exactly to plan, I couldn't find Bootcache.data Also the file .volinfodatabase
wasn't exactly the same. it was called volinfo.database
I'm just wondering if those instructions are for Intel based macs based on the date.
http://superuser.com/questions/233531/how-can-i-resolve-the-error-mediakit-reports-partition-map-too-small
"Why not just boot into single user mode? Hold down command+s on boot. Performcheck disk and then mount the drive.
Go to /Library/Caches and /System/Library/Caches and remove everything in those folders.
Then go to /private/var/db and remove BootCache.data, BootCache.playlist and .volinfodatabase. Reboot and use Disk Utility again. Just did this here and it worked moving from a 120GB SSD to a 250GB SSD. Was getting the dreaded medikit error too small or whatever.
You might just have to remove the .volinfodatabase. Try that first. If that doesn't work try the .volinfodatabase again and the BootCache files. If that doesn't work try what I tried."
If anyone knows how to resolve this on OS 10.5.8 I would appreciate it.
:O
:O
