ibook G4 1.2Mhz
Unknown_K
68040
Completed my G4 laptop collection with a working 1.2Ghz G4 iBook 12". Cheap ebay find where the cable to the HD had popped off the motherboard (easy fix if you like removing a 100 screws).
Anyway I now have Powerbooks: 12" 867, 12" 1.33Ghz, 15" 1.5Ghz
Ibooks: 12" 1.2Ghz and a 800Mhz 12" with a bad screen that I will replace sooner or later.
Also an iBook G3-500
Any major variants I should be looking for? Not sure I even want a Ti G4.
The TiBooks get a bad rap, get a cared for one and be happy with it. I like mine.
You might want either a final model iBook G4 or a final AlBook, the iBook gained a CI capable GPU and the final 15 and 17" AlBooks got DDR2 and a HiRes screen, as well as a scrolling trackpad.
