iBook FW 366Mhz: DVD playback capable?
Byrd
68LC040
Hi,
I just picked up an iBook Key Lime - the model with firewire - it's the 366Mhz model with standard 24X CD-ROM drive. I'd like to soup it up and put a DVD drive in there for movie playback - but from what I've read only the final 466Mhz "special edition" supports this.
However, on paper (apart from CPU speeds) the two revisions are exactly the same - both having an 8MB ATI Rage Mobility 128 graphics chipset. Even the model number is the same. I'm betting the 366Mhz CPU can be overclocked to 433/466Mhz - will DVD playback work without issue?
Thanks
JB
It will work if you use OS X. It has built-in software dvd support unlike OS 9 where support for DVD video was limited. You can use DVD player or VLC and it should work fine on your iBook after you install the replacement drive.
As Strimkind said, it should work fine, the fact that you have a Rage Mobility 128, and not a Rage Pro (like early iBooks) will help quite a lot...I once tried to play a DVD in VLC on my tray load iMac 333 (G3/333, 6MB Rage Pro), and it was almost unwatchable, so don't get your hopes up, but don't give up hope either.
I just put a DVD drive into my Indigo Clamshell, I have not overclocked it, but playing DVD's does not work (well)
in OS X. I used a version of VLC appropriate to OS 10.3.9.
This might be because the encoding is done in software and 366mhz just ain't enough hertz.
However, I can report that upon booting into OS 9.2.2 that the Apple DVD player plays them full screen
and without issue 8-)
I guess this must be because Apple DVD player software utilises directly the Rage Mobility chip.
+ having 576mb of RAM, probably helped ;)
