HP DIP Switches
On my new HP Vectra from 1985 I can't get any video on the monitor (also HP branded), there are DIP switches on the video card, but I have no documentation.
It's an EGA display adapter, and so is the monitor.
The video card has the EGA (DB-9) connector, two plugs (RF?) and a little knob that flips back and forth.
:EDIT:I know why Macs were so popular back then compared to the PC equivalents.
Can you confirm the monitor works, does the brightness increase the brightness of an otherwise blank screen? You may also see flyback scans.
I found on one site that for an EGA monitor the dips need to be off on on off off off. Of course in order from 1 to 6. All the monitor was doing beforehand was making a high frequency noise that made my headache even worse. I will try the new DIP settings ASAP. And I couldn't see the monitors brightness cause the sun was shining directly on the screen.
It has MS-DOS 6 and Windows 3.1 at the moment. Windows is quite unusable because it has a 286 @ 8mhz. I need to find Windows 2.0 before continuing.
OS/2 does maintain compatability with DOS programs, right?
Might be time to learn another OS. Windows, DOS, UNIX, Mac OS, Mac OS X, and now OS/2!
:EDIT: Shame on me for not even giving the full specs of this machine!
80286 8mhz, 1664kb RAM, 5.25" DS floppy, 3.5" 1.44MB floppy, and one very loud 5.25" HD (20 or 40 MB).
As long as OS/2 will work, I'm happy :)
Mainly DOS compatibility is what I need, I will also need Excel, Word, etc. BTW, any tips on how to open this old HP mouse, as it gets gummed up when you move it (i.e. it stops moving periodically).
Yes, I'm pretty sure. You actually made me think twice... :)
I'm a doubting Thomas....
Microsoft originally marketed a spreadsheet program called Multiplan in 1982, which was very popular on CP/M systems, but on MS-DOS systems it lost popularity to Lotus 1-2-3. The first version of Excel was released for the Mac in 1985 and the first Windows version (numbered 2.05 to line-up with the Mac and bundled with a run-time Windows environment) was released in November 1987.
