Houdini II DOS compatibility card 486-66 with SB16 - software, hardware considerations on 68K
I don't think it will, no.
Change resolution to different options in the video options in the PC Setup CP until it works. What options do you have in PC Setup for video?
What Mac video adapter do you have? How are the little switches set? Do you have a second monitor handy?
I see 3 options in PC Setup CP: Apple 14, Apple 16 and VGA. Tried all of them, but same result: black screen...
I have 2 MAC video adapters. One with 10 DIP switches (http://myoldmac.net/FAQ/RGB-VGA-DIP-switchconfiguration.htm) and an other one UnimacFly with 8 switches (https://aucview.aucfan.com/yahoo/h188251091/). Tried both in several settings... Starting to give this up :(
I have an Apple 14" CRT (M1212), but it seems not working any more. I also have an EIZO 17" CRT. Should I try that one as well?
I think your issues are just settings :)
They're fiddly.
To start, I'd suggest unplugging from the main Mac video output and plugging a monitor directly in there. Use the basic VGA adapter in that port. Use the 10 switch on the DOS card monitor.
I... Think I had best luck with the 14" setting on mine? I could be wrong, I forget. I don't have it set up at the moment.
Make sure the DOS card cable hasn't worked partially free inside your case.
Set the DOS Card video switches to Apple 13" (640*480).
Hi!
I've just tested my adapter with dip-switches on my 6100 and my LCD monitor still does not like the settings that came from the DOS card for information.
When I am in MacOS (7.5.3 on mine), I have no problem but when I switch to the DOS card, the display works few seconds then the monitor switches itself to standby mode. The only way to get it awake is to go back to MacOS.
Also, I tried booting/restarting/switching PC with the control panel buttons and it seems unreliable. The "good" way to make it working is clearly to used the shortcut "cmd + return".
I am using PC Setup 1.6.4.
Odd that the PC Card would give monitor troubles. It is outputting standard VGA text mode on boot, which most all LCDs should support. I never had a problem with it over the years on CRTs (Apple and generic PC), and LCD displays. The PC Card also doesn't care about sense code DIP switches as the onboard SVGA controller has no concept of them. I am running the card on 8.6 with PC Setup 2.1.7.
I can't speak for the Houdini II card, but the Houdini I card definitely pays attention to the sense code. It's fed into the 26-pin connector going to the card. I'd be shocked if the Houdini II behaved differently in that regard.
If I boot up with DIP switches 145 (640x480@66.7Hz) the PC Setup control panel shows this:
When I boot the PC with this configuration I get a black screen on my monitor and my Epiphan AV.io capture card. My monitor says the signal is out of range. The AV.io claims it's an interlaced 1024x768 signal (WTF?) but shows a black screen. I also tried 1467 just in case it was a weird sync issue but same problem.
If I boot up with 235 (VGA) instead it shows this:
In this config I get good video. Interestingly the Epiphan card says it's 800x600, but my monitor says it's 832x624. Seems like it's picking Apple 16" even though it says VGA...
There's definitely some funny business going on with the video signal though. The above tests were with one monitor. If I switch to two monitors (145 on Mac, 235 on PC card) then the PC Setup control panel defaults to VGA but also lets me select Apple 16".
In this case I am getting normal VGA 720x400 instead (with VGA selected).
If I pick Apple 16", it goes back to the 832x624@75Hz signal instead, again mistakenly called 800x600 by my AV.io.
What exactly does all this all mean? I dunno for sure. What I can say is the card (although admittedly Houdini I in my testing) definitely detects the sense code as well as whether the Mac side is plugged into the crazy cable. So a no-video situation could definitely be caused by VGA adapter switch settings. For what it's worth, my random no-switch VGA to Mac adapter seems to be hardwired for VGA mode and it works fine too.
BTW, I noticed that the control panel's display settings don't reflect my changes to the DIP switches unless I power the whole machine all the way off and back on. A reboot doesn't cause the control panel's detected value to change. This might mean the same for the DOS card's display logic too. So it might be wise to change the cable setup only when powered off just to be 100% sure.
Still I am not able to get picture of the PC, seems like the monitor receives a signal which it cannot take.
I'd definitely recommend trying combination 235 (or 2367, depending on the monitor's sync capabilities) on the 10-switch adapter. The Mac supports it, and it causes the PC card to output something that seems far more compatible than what I saw with the 640x480@66.7 mode.
Also, I can't speak for Houdini II, but Houdini I doesn't support sync on green. So you definitely need switches 5 or 67 enabled (not all 3 though). In fact, the easter egg you get by command-clicking the version number even provides a way to disable sync on green on the Mac side because the Mac side supporting sync on green and the PC side not supporting it caused problems with some monitors back in the day.
It's possible Houdini II works different from my experience with Houdini I...but I doubt it's that different from a display standpoint. Just thought I'd share a few of my tips since I've been playing with this setup recently in my 610 and have experienced lack of video myself with some adapter configurations.
Hi!
Sorry to unearth this topic but I think I should share one of my strange experience.
One of my friend is working on adapting CP/M x86 to standard PC BIOS and we truies to boot my Houdini II with it. At first it seemed to work then freeze. Ok, it is a WIP so why not but after that freeze, we were unable to reboot on my MS-DOS "hard drive". The only way to get back to a functioning Houdini II was to boot on a bootable MS-DOS floppy !! Then we were able to boot on the HDD.
We tried many times, same behavior. Like if the 486 was locking itself in a strange state and the only way to unlock it was to make it boot on a « standard » floppy.
