Hello you wonderful bunch of Mac'ians!
While my my "other Mac project" is currently on-hold I dived into a PB140 restoration... initially it went quite smooth -thanks to the great videos of Ferrix97 (Grazie mille, mio eroe!)- replaced the fuse, reanimated hard-drive and recapped the screen/inverter.
The last issue I have now are 2 black bars in the lower left quadrant - Does one of you brave souls have a hint for me, where to look?
So far I've re-checked all caps, had a close look at the flexible flat-cables, chips and traces with a microscope, no goo or visible shorts...
Thanks a ton for helping,
Cheers, Axel
Cheers, Axel
