Hello everyone,
I recapped the logic board and the analog board of my Macintosh Classic but when I turn the computer I hear the chime and then I get a gray screen with a pointer I can move using the mouse. It will no go further than this gray screen.
If I disconnect the hard drive I get the usual floppy with the question mark. I tested the hard drive power cable with a voltmeter and I got a strong 12V and 5V respectively. I guess the hard drive may work but has the boot files corrupted.
Something that caught my attention and I don’t know if it is part of the problem is that there’s no way to make it boot from the ROM using command+option+x+o, I tried doing it with and without the hard drive connected with no luck. I don’t know if the keyboard has a problem also but as I said before the mouse at least works when I move it during the gray screen.
For now I don’t have any floppy disk with an operating system to try, I count on booting from rom but I don’t know why it’s not working.
I also washed the logic board to remove all the electrolytic fluid from the leaked capacitors and then used some Qtips with IPA to clean the stubborn parts.
Thanks for the help.
