Help with Macintosh plus!
I recently received a Mac plus, it appeared to have a fan mod but other than that nothing done to it, but the crt will not come on, and when I tried to reflux it it still would not turn on, and had a low flup flup flup noise and still would not turn on, I found the scimarics of the anolog board and found non of the voltages on the board mached, idk what to do , just give it to me straight, is it going to be a cheap fix or is not fixable, thanks
aiden
I looked at that... nothing seemed to fix it, I may just need to buy a new abloom board, idk I’ll keep on looking
let me know if you can find anything that might fix it thanks!
Have you made sure that everything is hooked up correctly between LB, A/B, CRT and Neck Board? If so, at this point I'd think posting high res pictures of both sides of the A/B and Logic Boards would be in order. Details of the fan mod might give some clues as to what might be awry as well.
Was made with a medal bracket, was held on buy nuts and bolts, don’t see how it coneects, and the computer is still making a low flup flup flup noise
