Working on a Macintosh IIsi for a client. The logic board and power supply unit (PSU) have been recapped. The unit starts up and boots perfectly, but after a couple of minutes, a white screen appears with some bars. The machine has to be powered down manually. I check my work; everything checks OK. Remove the additional memory, test, and remove the add-on ROM, same behavior. Any idea!
If the machine is cold, it will work for around
