Help with identifying some cables and adapters
Minja
Hi, got into possession of a big variety of different cables, mice and adapters. Most of them were easily identified but there are some that I’m not sure what they are for.
Some help is needed. Thanks in advance.
  1. Mac serial to some kind of PC serial, at a guess? 25-pin is probably to plug into a modem, but that's not guaranteed.
  2. A LocalTalk box
  3. Difficult to tell without being able to see the mini-DIN more clearly
  4. AAUI 10BaseT transceiver
  5. Probably also Mac serial to PC-style serial.
  2. A LocalTalk box
Thanks. No 3 is the same just longer.
5. May also be a Mini-DIN 8 RS422 to DB-9 RS422 adaptor (though the DE-9 connector may be the wrong gender for that - mine is 150 miles away ATM so I can’t check). This allows a Mac with a Mini-DIN 8 serial port to use serial devices designed to connect to a Mac 128K/512K/512Ke DB9 serial port. If so, this is what you’ll see when you tone it out:
Mini-DIN 8
Mini-DIN 8
DE-9DE-9
Function: RS422​
Pin​
Pin​
Function: RS422​
HSKo​
1​
6​
+12V​
HSKi​
2​
7​
HSKi​
TxD-​
3​
5​
TxD-​
GND​
4​
1, 3​
GND​
RxD-​
5​
9​
RxD-​
TxD+​
6​
4​
TxD+​
7​
N/C​
RxD+​
8​
8​
RxD+​
Shell​
Shell​
Oops!
…should also have said and vice-versa - for example this allows a ImageWriter II or similar to be serially connected to a 128K/512K Mac.
