Hey everyone! I could use some guidance with my Color Classic restoration project that I've been working on (slowly) over the last couple years. I have already done a main board recap. I have not done an analog board recap although I have the parts.
After doing the main board recap a year or more ago, I installed a SCSI2SD and the OS and had been using the computer off and on and it was booting just fine. Now, the other day I tried to turn it on and I got the flashing question mark indicating no drive found. I left the main power switch on for 24 hours and then tried booting again and it booted into the OS.
Does this indicate I maybe have an issue with the analog board? Or could this be something else I should check? I plan to do the analog board recap anyway but while I have it pulled apart again I'd like to know if there is anything else I should check.
Thanks for the help!
