Help!!!! The Dock is suddenly MIA in ubuntu . . .
Trash80toHP_Mini
NIGHT STALKER
68040
. . . how do you get back, it disappeared?
I've got a slight problem. I need to send HP_Maxi Back to HP and I slightly bent the ubuntu install on HP_Mini in the process of setting it up as a stand in.
What's the keyboard combination to put the Dock back on the left side of the screen on last fall's release?
Do I need to get to the command line to restore it?
Is there a KBD Shortcut to get straight into settings?
I hate animal names . . . but this time I don't remember the friggin # either.
clueless in Koala (?) Land,
jt :I
I fixed it, or it fixed itself more likely, apparently the dock got lost somewhere between two spanned screens. A trip out to the Graphite side of the MacPlaypen and then hooking HP_Mini up to the 22" 1080p HP LCD did the trick . . . poof!!!! . . . it reappeared automagically when I shut down the onboard LCD. Now it's working fine on the 20" 1200 x 1600 Dell on the Online Desk in the bedroom again . . .
. . . go figure! ::)
I'll leave this post up in case some other 'nix n00b has a similar problem.
